Rich Grossmann wrote:
Have the Superglide and love it.......however.... I was not aware until after buying it that you cannot hitch or unhitch it if the your truck is at an angle more than 10 degrees.. that's a challenge sometimes in tight parking spots...... rich
It's sixteen degrees - not ten.
You can remove the head if necessary for greater than that.
For the OP, "N-Trouble":
As others have indicated - not really difficult.
Never done one before - took about 4 hours, could probably do one in 2 hrs now.
In 2005, I installed a 3300 16K on my (new) '05 SB SRW Dodge.
Went very smoothly.
Think that's the older model (way tubes require lubrication) - prior to the newer model you purchased.
Used "under bed mounting" brackets, for a "clean bed" when hitch is removed.
No clue what poster is talking about in re: "floating the bed"..:h
(No need to unbolt or loosen any bed mounting bolts, etc.)
Hints:
Obviously, read the directions carefully before you begin.
Check your measurements twice.
Don't hesitate to call the Pullrite tech line if you have questions.
A "helper" is handy for moving the hitch around and for holding wrenches on opposite ends of bolts you are torquing.
Not necessary, but I put the rear of the truck up on jack stands, pulled off both rear wheels for easier access to the undercarriage.
Only drilling required (for Dodge) is for the 4 holes for the "mounting posts" through the bed.
Have a good (metal) hole saw for that.
BTW - There was a poster on a thread like this a few years ago, who took his *NEW* D/Max to an "experienced" hitch installer. Whatever brand of hitch it was, it required holes to be drilled in the frame.
Installer drilled holes in the wrong place..:(..:M
Lengthy discussion (posts on the forum) about what to do.
Fortunately, the installer found a different brand of hitch that utilized the holes they had already drilled.
So much for "professionals"!.:R
IMO - my preference = DIY - rather than have somebody else screw it up.
