avvidclif1
Jun 29, 2014Explorer
pianotuna wrote:
Hi Catraveller,
I check polarity, I check voltage, then I load the connection and check it again. If I'm at a 50 amp service (rare) I use a break out box to check both legs.
I just got my Magnum boost inverter installed. That, I believe, may obviate the possible need for an autoformer. I'm still learning how to use it.
If I had a 50 amp service in the RV I would consider a top of the line unit from progressive. But, I don't, and this is destined to be my only RV and full time home for five years.
Any time you plug into campground supply you are at risk. Use of the inverter only protects you if you are not plugged into anything else. If you never plug into campground supply and are completely self contained you are not at risk.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
