WrightOn's avatar
WrightOn
Explorer II
Apr 12, 2018
Surge Protector
What do you use? I'm looking into Progressive Industries EMS-PT50X Portable RV Surge Protector - 50 Amp ($335 on Amazon).
How much difference is there between the expensive brands and the less expensive brands (Portable Surge Guard Protectors, 50 amp - $78)?
Signed, electricity knowledge-deficient camper
  • With 30amp service a portable one is ok. With 50amp service a hard wired one in much better. If you loose neutral on a 50amp circuit you burn up all the AC items with 240 volts across them. Hard wired just ahead of the circuit panel protects you from problems with the power cord and cord reel if you have one.
    PI with remote is the way to go.
    Chris
  • Go whole hog or measure before you plug in for 50 amp service.
  • get one that reset itself. not one that has to be sent back to get reset
  • I can tell you from personal experience the customer service at Progressive Industries is top notch. Had a minor issue with a 30 amp unit and they sent new parts out fast and gave advise on how to best install them.
    This is the one I decided on.. I just got it at the end of last season, so I only used it 1 time so far... ( Progressive Industries EMS-PT50X Portable RV Surge Protector - 50 Amp )
  • Progressive Industries EMS, either portable or hard-mounted.
    Hard mounting inside the RV is long term easiest. No loss, theft or forgetting to attach/detach issues.
  • I have a Progressive Industries EMS-PT30X This is the second season with it and so far I'm very pleased with it.
    Prior to this I had a TRC 30AMP Surge Guard for 9 years. Never died just did not trust it any longer and towards the end it was not reactive to low voltage. I had to replace the plug on it once and it's a sealed unit that TRC will not touch. Tough separating it since it is screwed and sealed with silicone but once inside it was easy to replace the 30 amp cord and plug. The progressive unit would be much easier to service.
    My vote is on the Progressive unit.
    Here's a thread currently running:
    https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29615143.cfm.
    See my comments on the portable PD units.
    Lyle
  • Progressive EMS portable 50. lifetime warranty. don't want to skimp on electrical protection
