psuce
Apr 27, 2015Explorer
"IF" you have to do it yourself, local Tractor Supply carries 9/16" diameter shackle bolts with nuts. I replaced all of mine on an open car trailer last year. I think they are around $10-15 each. Make sure of the diameter of your bolt as 9/16" is not a typical bolt you can find at Lowes. Also check the bushing inside the spring eye to make sure it's not beat up from the bolt being backed half way out. Tractor supply sells them also if it's a standard size. It's not a hard job to replace them if you need to do it yourself.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
