psford
Apr 27, 2015Explorer
fj12ryder wrote:
So he should just lie if there's a problem later and he's asked about this? Nice advice.
The problem already exists , replace with OEM Bolt, and nut ,there is no secret to a shackle bolt ,and nut. Get one at any axle shop. Check the nylon bushing replace if necessary, probably chewed up a bit.
Its could of been bad, but at this point it was caught the sky is not falling. Contact whomever you want on the issue . IMO the hassle is not going to be worth it, nuts come loose all the time, and that can very well be the issue here. . Probably all he is going to get told is its his issue ,should check the suspension, which he did, and caught the problem.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
