PRodacy
Apr 28, 2015Explorer
RCMAN46 wrote:
The bolts on my trailer not only had the knurled portion on the head end but on the thread/nut end the threaded section is smaller diameter than the body. This gives a shoulder for the nut to be torqued against and control the distance from the nut to the head.
My shackle bolts are not anything you will find except at a trailer supply or someone that carries shackle bolts. They are a special single purpose item.
Mine look like these.
Wet Bolts
I had not heard of wet bolts before. Can someone explain how they work? The link didn't provide any information. Do they just provide a layer of grease between the bolt and sleeve? Is there a grease seal somewhere on them? Zerk fittings? Thanks. Always good to learn new things.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
