Chuck___
Apr 10, 2020Explorer
Suspension & Shocks: doing maintenance & upgrades. Suggestions?
I am trying to gather information on doing some repairs and or maintenance on my RV and truck wile we are stuck home. Not looking gold plated parts, but don't want cheap stuff either. The more information I can get I hope to be better educated on my choices.
Here some for the things I am looking into.
Comfort Ride Slipper Springs and or including the Comfort Ride Shock Absorbers is it the preferred system my many RVers? You think Comfort Ride is that much better than the MoRryde? I have yellow colored shocks on my 2010 DRV now. with the equid flex suspension. Heard that the factory shocks are black in color. The shocks just might of been change out once before. I purchase the RV used several years ago.
I now have a 2017 Ford 350 dually. Would you recommended changing out the shocks on the truck. Years ago I tried to do some research on shocks for my 99 250 Dodge. A lot of people said that the factory shocks on trucks are cheapest of the cheap and ware out fast, around at 20,000 miles. So at 75,000 miles I finally changed them out to heavy duty Bilstens. When I took the factory shocks off the truck, they seems to be functioning fine. Didn't notice any difference in ride at all. So, did some reading later on and a person who worked at a shock manufacturing company wrote a articular stating that the recycling yard is full of good shocks that people have replaced.
Tires: I believe the DRV manual and or tires recommend 90 PSI plus when fully loaded. That doesn't been that I been doing the tire inflation wrong all this time. I tried like hell to find what would be the ideal pressure on my Ford 350 dually from Michelin and Ford company and all I could get out of either was to go by the driver’s side sticker. 60psi in the back and 70 psi in the front cold fully loaded
Bottom line, I guest is that you just do the best you can with the information you have at the time.
