Me Again wrote:
rhagfo wrote:
Looks like he bought the TV before the 5er, the TV is more than capable of towing the 5er, he is just close to the low Class2 10,000# limit, maybe Texas has a higher registration cost for over 10,000# GVWR.
I truly believe that GVWR is a number the engineers and marketing personal pull out of the air!!
Russ as you know, not every one needs a dually or wants one. In Ken's case "2013 HitchHiker 38RLRSB Champagne" he needs one whether he wants it or not.
Depending on the year and make, the 250/2500 and 350/3500 had very little differences. To take a 10 or 20K hit to change from a 250/2500 to a 350/3500 SRW does not make economic sense in a lot of cases.
Given all of that in makes NO sense to buy a 250/2500 if one has a 5th wheel or plans to buy one. Like you I had the 2001.5 2500 RAM built like a 3500 SRW before I purchase the larger 5th wheel. If they would have offered a 3500 SRW in 2001, I would have bought that.
However the doom and gloom of 250/2500 towing over GVWR has no standing in Federal Bridge Weight laws and states that license tonnage.
This is a learning process, snowbird parks have for years been full of 250/2500 towing very large 5th wheels. This is slowly changing as trucks age out. Few changed them out early for a near identical truck with different door emblems and placard. Chris
Yes, Ken needs a DRW, but the OP is a different case. His 5er is actually lighter than mine!
Technical Specifications:
2013 Crossroads Cruiser SK 305
Length 32' 10"
Dry Weight 9,090#
Payload Capacity 3,215#
GVWR 12,305#
Hitch Weight 1,905#
Easily towed/CARRIED with a 2500 of 2012 vintage!
My dry weight is 9,820# and a GVWR of 12,360# towed at just over 11,000#.
