Cummins12V98 wrote:
buckdaddy wrote:
I'm thinking of adding air bags to the rear suspension on my 06' Ram 2500 since I started pulling an 8300lb 5th wheel. Any recommendations on brands & gotchas as well as psi settings. Did it make a difference in handling, ride quality, or stance of vehicle? Right now its a little squat when pulling.
At that weight you should not need anything!
X2!
I tow 11,000# with my 01, and don't engage the upper overloads.2,000# on the pin. How much does it squat when the 5er is loaded?
It sounds like that TV/5er would have failed my weight test. Hitched up before signing the papers, I was still setting better than level, if it would have squatted too much would not have bought.
