fj12ryder wrote:
joebedford wrote:
Shouldn't the equalizers be the same dimension eye-to-eye?
They should be if the distance between axles is the same, but this trailer has different distances between the 3 axles. Dexter shows two different length equalizers, and which one you need is determined by the axle spacing.
What I don't know is if OP measured the distance between axles or axle hangers. If the wrong equalizer was put in, that would affect the distance between axles even if the hangers are the right spacing.
Also, I've had a spring shop put the wrong spring in my rig. Maybe when he got his springs replaced, they put in two different sizes.
