phemens's avatar
phemens
Suspension shackle failure - best replacement?
We were packing up to leave from a close-by campground this morning. Raised the 5er with the landing gear, and I heard some creaking didn't give it much thought, continued to pack up. When ready to leave, did our walkaround and were unpleasantly surprised by this:
On the driver's side, failure of the shackle between the equalizer and the rear leaf spring. Not sure what caused the failure, any ideas or is this just wear and tear? We bought the trailer used last fall so this is our first season with it (it's a 2012).
We were able to carefully get home and the rig is parked for the winter. Looks like a straight-forward repair, but I turn to the collective wisdom of the forum. What would be the best replacement solution? I did a bit of googling and found some equalizers with rubber shocks and what look like heavier duty shackles, is that the best solution? The leaf springs look good, everything else looks normal.
  • Yes, was planning on doing them all for sure! I have the factory installed ones. I'm not sure what brand I have right now, does it make a difference when ordering the new one if I'm replacing everything (equalizer, shackles, etc)?
    The MORyde link is the kit I was looking at, plus the equalizer (Link)
    There are 2 options for the equalizer, 33 or 35 inch. What is the best way to measure this on my 5er? Center of hub to hub?
  • Did you have greasable pins or just the factory ones with the nylon bushing. Either way get the moryde heavy duty with the bronze bushings and grease fittings. The ungreased factory ones have a very finite lifetime.
  • Since you're going to have to do one, do them all. Since you're going to do them all, get a wet bolt kit, that includes heavier shackles, bronze bushings and new bolts.
    Lyle
