GrandmasHomeExplorerSep 04, 2013SW6DE water heater and outside frame sealingWhat sealant do I put at the bottom junction of the outside frame/access door and the water heater housing to keep the weep from going to the frame? Right now, I switch on the propane for 10 minutes t...Show More
RvpapaExplorerSep 04, 2013Why not fix it properly. Install an accumulator in the water line in the trailer and you won't have any more drips. Art.
Related ContentAtwood water heater problemSealing heater from allowing outside air coming inside.Water Heater Replacement RecommendationsReplace insulation inside heater column.New Outside Stairs
