jepalmer's avatar
jepalmer
Swapping out king pin
Is removing standard king pin and replacing with a Demco Glide Ride a DIY project?
  • Not sure about Demco Glide Ride king pin set up. My Bighorn has 10 bolts holding king pin to the 5er frame that I torque to 110# per Lippet manual. As long as you can get a little help lifting off old unit and lining up holes with new unit to the frame you should be fine. If your holes do not line up, well that is a brand new issue to solve. Good luck and keep us posted.
    Lakeside
