dedubExplorerApr 24, 2013Swapping tiresI need to swap tires around on my 5er. Can you jack under the U-bolts one-by-one and get away with it or is it bad JuJu?
JIMNLINExplorer IIIApr 24, 2013I use the axle tubes next to the U bolt. I jack all my trailers with std leaf spring suspension this way. Torsion axles need a different plan.
