Ropdoc's avatar
Ropdoc
t handle on valves
Hello I have an 07 Raptor 3712 and 2 of the drain valve handles {black and gray water} have broken so the valves are hanging free. I have never repaced anything like that. Can anyone give me addice on how to remove and replace? Also if you know part numbers for the valves that would be awesome.
  • Ropdoc wrote:
    The thread portion of the valve broke that holds the whole assembly to the frame. I need to replace the whole thing. :h
    You can replace just the cable and T-handle. Make sure you get the right length. If just the cable sleeve got detached from the threaded portion behind the frame, you can use the solution I posted on your previous thread.
  • The thread portion of the valve broke that holds the whole assembly to the frame. I need to replace the whole thing. :h
  • Hey Ropdoc, you posted a similar problem 2 days ago. So, what's the real problem? Valve handles or valve bodies?
  • Hi Ropdoc, one of my two handles broke,and I bought a replacement from the local rv dealer. It's a 30 second repair. Just screw it on. Are your valves broken as well, or just the handle?
