RustyJC
Mar 02, 2015Explorer
Years ago I had a Jayco Designer XL 3610RLTS with a vertical pin box - the truck's tailgate would hit the trailer if I tried to hitch with the tailgate down. The simple fix is to make hitching up a 2 step process:
1. Back toward the trailer far enough to connect the trailer umbilical (I've always had a 2nd 7-pin Pollak-style receptacle in the bed) and close the tailgate.
2. After connecting the electricals and closing the tailgate, continue backing until the kingpin seats in the 5th wheel hitch.
If your trailer manufacturer will allow it due to trailer frame strength considerations in the pin box area, an option you might consider if the above is not acceptable to you is a longer extended pin box on the trailer. In my case, Jayco would not approve an extended pin box on that particular 5th wheel.
Rusty
Rusty
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 26, 2026
