Bierp's avatar
Bierp
Taking the plunge
...now I just hope someone put water in the pool. :)
Signed the papers yesterday on a new 2018 Montana 3950BR. Scheduled to take delivery a week from Tuesday.
Traded in our TT for the new 5er. Going to try our hand at full-timing. Should be quite an experience. Hopefully a good one.
Towing with a 2016 F-350 Diesel Dually, 8 ft bed. Love the truck, but it didn't come with the 5th wheel/gooseneck prep. I've got the OEM parts in hand for that, but have to wait a few days to get it installed.
Went with a 25k B&W puck hitch. Obviously more than I need today, but I know I'll want that capacity for our next rig. We eyed the DRV 24k GVWR units heavily, but I couldn't quite pull the trigger this time. That will require a TV with taller gears than my current one. Next time.
I've had a pile of things added. Inverter, 4 6-volt batteries, Washer/Dryer, HD DirecTV dish (automagic satellite finder), EMS, 3rd AC (cuz, ya know, more AC!) plus a number of smaller tweaks.
I guess my idea of 'roughing it' is poor wifi.
Anyway, the move from TT to 5er is exciting for us. DW and I can't stop babbling like idiots. (Admittedly, this isn't really a new condition.)
Looking through the 5er forums now. I'm sure I'll have the standard boatload of questions soon.
  • "Went with a 25k B&W puck hitch. Obviously more than I need today, but I know I'll want that capacity for our next rig. We eyed the DRV 24k GVWR"
    Great call on the B&W puck hitch. The Ford puck hitch is rated at 20K. Simply compare to REESE and CURT if you are concerned that the hitch is 20K and the others are 25K. I would trust the B&W to a much heavier weight than the other two any day. I would pull a 24K DRV without a second thought with the B&W.
  • I would say go for it, all except the Winegard Travler. Please DONT! I have had Travlers on my RV for probsbly 10 years. In that time I have had two failures that required I send the whole thing back to Winegard. Last one last fall cost me a thousand dollars to make it work again. All that for an antenna system that I have been able to use a hand full of times. Remember, putting a dish on the roof means you must have a chear line of site to the sats to get reception. So, unless your going to be sitting in the desert its a waste of money. For less than 300 dollars you can get a ground based system that will work 99.5% of the time.
  • Congrats, yes, exciting times ahead for sure!
    Wise choice to install OEM puck system, then adding the B&W 3305. You are in for a great towing experience.
    The Montana should serve you well! It wouldn't matter if you had gotten the DRV, as you'd still be roughing it, due to poor wifi most places.
    Jerry
