RAINEYTXX
Nov 08, 2013Explorer
45Ricochet wrote:
I believe the tires on my dually are even closer (sidewall to sidewall)
My 43' DRV triple axle is about the same! If you have a blow out-you replace the tire on the same side anyway! Yes, the marketing of "wide stance: is towards the stability but I gotta think in tight turns, closer is better for axles/bearings/spring links etc....
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
