flrp's avatar
flrp
Tandem tires on the Cedar Creek Silverback
I am thinking about buying a 2014 Cedar Creek Silverback 5er but I am concerned about the space between the tandem tires on the unit. I have owned 4 fifth wheels so far in my life and none of them had the tandem tires so close together. The space on the Silverback appear to be about 4 inches (my estimate)apart. I have looked at other new 5th wheels and they appear to be about 10 inches space between the tandem tires. Plus the units I have owned were in the 10 inch range. My concern with the tires being so close together that a tire blow out could impact both tires on the same side of the unit. In addition I have had a leaf spring break on a Montana and the axle twisted which in my opinion would have cause the two tires on the opposite side to have rubbed together compounding the problem when the leaf spring broke. The question is, does anyone understand my concerns and have similar ones with the Silverback unit? In addition with the two tandem tires being so close together I would believe the 5th wheel unit would be more unstable acting like a play ground teeter tot when traveling down the road. Anyone have thoughts about the tandem tires being so close together on this unit.
  • On my Keystone Challenger I could not get 2 fingers between them. I recently changed my springs to a little shorter and got the egua flex equalizer and now have a little over an inch between. I have never had a problem with the spacing the whole time with it
  • donn0128 wrote:
    In 8 years with distance between tires of about 1-3/8 inches I have never had any issues. But them again I dont have junk ST tires on my fiver
    Yep....that's about the distance between tires on my 5vr
    No problems with them being that close.
    LT tires, wheels balanced and shocks....rides smooth
  • On previous two TTs and one 5er space was between 2 to 4 inches, about the same as current Rig.
  • On my 3rd Cedar Creek. No problems with tires yet, and probably more than 50,000 miles between the 3 rigs. Current one has G614 tires and 25,000 miles.
  • In 8 years with distance between tires of about 1-3/8 inches I have never had any issues. But them again I dont have junk ST tires on my fiver
  • I'm sure the chassis engineers that the Chassis Manufacturer Forest River uses for the Cedar Creek...most likely Lippert or Leland....use Computer Aided Design to engineer the chassis for that specific 5er.
    My Jayco 5er has a mere 6" seperating the tires. There are a few brands that toyed with wide apart wheels, 18" or more...Keystone for example. Supposedly gave a more stable ride. Different trpes of suspensions would warrent the tires to be closer together or farther apart too.
    If it really bugs ya call the Cedar Creek Factory in Elkhart and ask to speak to an engineer.
    Mine are about 2-3 inches apart. I wondered about that until I started reading about the sidewall stresses on trailer tires when turning and especially backing. The closer they are together the less side loading and the way I see it any help given trailer tires is a plus.
  • If I'm not mistaken, according to Dexter the suspension people all that's needed is one inch between the wheels. I have changed my tires to Michelin XPS Ribs. They have a little diameter than the tires I replaced and they wind up with about 1 1/2" inches between. Never had a problem. I don't think there is any difference between the spacing from one brand to another as they almost all use the same length springs and equalizers. I don't see how they can from front to back unless the suspension is all worn out...
    B.O.
  • I have a 2013 SB with less that 2" between the tires. I wasn't worried until now. Ignorance is sometimes bliss.
    Jim
  • Our Cameo has less than 4" between the tires with G614's. I see no problems with it. Have owned 4 fifth wheels and don't remember having ever even seen one with 10" between the tires. Make/model you are comparing to?
