bcew99's avatar
bcew99
Tank heaters
I have a 2021 Winnebago toy hauler and my packet had a booklet on tank heater pads,
The underside is insulated and I don’t see a controller or power box for heaters. Is there any way to figure out if the RV has tank heaters?
  • jdc1's avatar
    jdc1
    Explorer II
    They probably are. killing your batteries If there is no switch, I'd put one in right away.
  • Facon heating pads book says they turn on at 45 degrees and turn off at 68. I haven’t used the rv for a month and the batteries were dead even with small solar charger. But its been getting cool.
    Thought maybe the pads are sucking the battery down
  • If they have actual heading pads I'd think you'd have a switch some where. Mostly RVs that have enclosed underbellies allow some of the heat from the heat ducts to heat the space. Was it listed on the spec sheet when you bought it?
