valhalla360
Jun 25, 2018Navigator
You can get them in electric or propane variants.
- Electric struggles with creating enough heat to keep up with a decent flow of water. Think about it, if you have a 5gal/min flow rate, it needs to heat a 5 gal bucket of water from 50F to 120F in 1 minute. Most RV's and Campsite electric posts can't provide that kind of power, so you get derated units that are very marginal.
- We had a propane version on our boat and it struggled to match the heat output to the flow rate. Below a certain flow rate, it would shut down and you got cold water. Then when you opened up the valve, it would get scalding hot for a second before settling back only to get cold when you turned it back down. Unless you have unlimited water so you could just leave the water running at a continuous flow rate, it just didn't work.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
