Lynnmor
Jun 25, 2018Explorer II
valhalla360 wrote:
- We had a propane version on our boat and it struggled to match the heat output to the flow rate. Below a certain flow rate, it would shut down and you got cold water. Then when you opened up the valve, it would get scalding hot for a second before settling back only to get cold when you turned it back down. Unless you have unlimited water so you could just leave the water running at a continuous flow rate, it just didn't work.
I just cannot see why anyone would want or need these things. What are they trying to accomplish? If the usual tank type can't supply enough hot water, it is time to re-evaluate your water usage.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
