NMDriver
May 02, 2017Explorer
In general between the end of June and the end of Aug elevation determines the average day time temp. If you are under 5000ft it will be over 100 in the daytime, which will last until 2200-2300, 5000-6000 and it will be in the 90's, 6000-7000 and 80's will prevail. Keep in mind that the nigh time temps will drop by 20-30 degrees. The early mornings are the best time to be active.
IMPORTANT: If you are away from civilization have 1 gallon of water per person with you.
About Fifth Wheel Group
