allcool
May 03, 2017Explorer
Stude55Dog wrote:
but unsure of how hot it will be
Was in Phoenix to S.Cali to dunes at Glamis, end of August.
Phx was 117° mid day. 1:00am at nite was 108°, dry heat...lol
See you are from Florida, so am I. Don't let that dry heat vs wet heat fool you. 117° in Phx august temps was brutal. I think I lost brain cells from that trip...
Opening the RV door felt like a blast out of a pizza oven. Both my RV a/c(2) blasting full blast, working in tip top shape, could only get the RV down to high 80°to 90, in the sun. In a covered RV spot, got it down to high 70's... thank God for covered spots.
Can't even be outside in the sun at all for any length of time at all if you don't want to be in pain, imo. Trying to walk barefoot would not just be painful, but probably give you bad bad burns on your feet.
On I 10 going west from Phx, the sides & median of the road were covered with tire carcass piled high. At first, looking at the piles of tires that were so destroyed and piled 3-4 high on top of each other, could not even tell what they were at first. Really, could not even tell they were tires. Till we saw the big state DOT truck picking up the tires pieces with its huge dump truck bed full to the top. This was all down 10 for as far as you could see till we got of at Blythe Cali..
So better have some good tires and some spares if you intend to travel in the SW summer time. And don't forget some good flip flops...
And better make sure your ac is tuned to max efficiency, you'll surely need it to not break down.
jmo
About Fifth Wheel Group
