In the way of an update and to close this out.
The fix offered was to either replace all of the flooring in that level with new flooring or to remove the the flooring from the island to the rear of the coach. Then add carpet to that area. The coach with the damaged floor was a variation in the floor plan. Most units have carpet from the island to the rear wall.
And of course the slide would be adjusted to prevent a repeat of the issue.
We are passing on this particular unit anyhow, because the height is too great for our storeage building's 13 ft door opening.
Thanks for the replyies.
