RamTXExplorerMay 14, 2014Temperature Differential for Coleman Mach ACHave a Coleman Mach 15000 BTU AC unit. Does anyone know what the temperature differential between return air and discharge air is? I know on cars and houses it should be about 20 degrees F. Thanks.
RamTXExplorerMay 15, 2014Great responses all-info will definitely help determine if unit is working at peak efficiency.
Related Contentcoleman Mach - Temperature Differential model 8333e856Differential ServiceColemanDifferential fluid changeColeman Mach zc thermostat showing opposite temperature
