spud1957
Apr 19, 2015Explorer
leeper wrote:
I can not believe that no one noticed you said you lowered the jacks and then tried to pull the release handle. You CAN NOT pull the hitch jaws open when the jacks have raised the 5th wheel up, putting lots of pressure on the pin box. You can only open the hitch when there is NO pressure or force on the pin and pin box. If you are not careful, you can get killed trying to unhook. You need help from someone whom knows what they are doing. Until then, STOP and GET AWAY FROM IT!
Oh yes you can!! The pin has 2" of surface for the 1/2" thick jaws to grab. With the wheels chocked, I raise the pin until the trailer plate is off the hitch plate, maybe 1/2", then pull the handle. Doing this, it takes all the pin weight off of the truck suspension. So when I pull away, the truck does not rise up.
s
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
