unsavorycharact
Apr 23, 2017Explorer
Hi, quick update
Pics with Truck and TH attached, no wd hitch wasnt squatted too bad
Drove semi wet (but no load) from Napa, CA to Half Moon Bay, where I was "Lucky" to get a parking spot for these things where I didn't have to cross a bridge and traffic to get to (east bay), nothing close to SF, I spent over a day calling every place I could find
Drove fine on hwy, was doing 75 and didn't even know it (Ecoboost V6 very quiet)
Backing this thing into the corner spot in the gated lot was an adventure too, good thing there werent other people there :)
I also stopped at CAT scale in South SF and did three runs thru, disconnected the TH since wasn't busy
Weight varied, dunno if scales and or if they took weights while I was outside truck adjusting things
Truck wt 6520
Trailer wt 3620
I think my tongue weight was 440 w this
Also, did some rough estimate of the stuff I've going to move from my apt
7 bicycles, rolling tool chest, 5 snowboards, a bunch of boxes (actually need to figure out it it will all fit and be weighted properly)
about 2710
So 3620 + 2710 = 6330
Dual axle Trailer max is 7500, truck max is 8000 tow wt
Still somewhat below
I can box and ship stuff to make lighter if needed
This first coast to coast heavy haul will be a 1x thing and my planned north america road tripping will be much lighter
I'm doing the calcs on the all the weights after this post
Next major hurdle is WD hitch
Equalizers come in 6000 and 1000lb versions and none were in stock for my timing, leaving w/in a week and i'd be at the limit of the 6000lb ones
Wound up getting
Husky centerline WD 8000lb on the way, supposed to arrive wed
I have to swap out the ball w 2" (what my trailer has) and torque the new one
I bought a huge torque wrench and 3/4 socket set
RV place I bought said they'd install for me if needed, but from what I read, supposed to be installed when loaded
Prob not a good idea to drive it loaded to place 75mi away thru hilly traffic
Im going to try and install the WD hitch in the dirt parking lot unless I can find somewhere closeby thats paved and level and not in anyone's way
If I get stuck on the install (while loaded with some stuff) I might have to bring the truck to the dealer anyway, but will prob need to make more trips unloading, then loading again
Another concern is how adjustable these 4 point, equalizer types of wd hitches are (since load will vary by maybe 1000-1500 lbs from initial install)
Trailer sales guy said TH is dual axle, designed to haul loads over the axles and shouldnt change the TW tremendously
I also bough a Sherline 1000 lb tongue weight scale
putting some pics in next post
Lotta planning
Truck wt 6520
Trailer wt 3620
about 2710
Wound up getting
Lotta planning
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
