dougrainer
Apr 23, 2022Nomad
https://www.etrailer.com/RV-Waste-Valves/Valterra/A70.html?feed=npn&utm_source=google&utm_medium=cpc&utm_campaign=Google%20%7C%20Shop%20-%20RV%20Waste%20Valves&adgroupid=132594025138&campaignid=15627245889&creative=570660415174&device=c&devicemodel=&feeditemid=&keyword=&loc_interest_ms=&loc_physical_ms=9027230&matchtype=&network=g&placement=&position=&gclid=CjwKCAjwx46TBhBhEiwArA_DjJM5pkt9LuQoCPprGzsTDb9ct_EsQ8kXojV-ijObt1gF0PlbfumTYRoCYREQAvD_BwE
This is what the flush nozzle looks like minus the yellow fittings.
The nozzle can be 2 places.
1. On top the tank and on the side
2. If on top the correct install place is on the opposite end of the dump exit fitting which means on the passenger side of the RV
3. If on the side, it will be between the 3/4 and full top of tank also at either the sides or rear side of tank.
4. FOAM is a PITA when attempting to work on a Tank. But, you should be able to find and follow the 1/2 inch plastic pex water line that comes from the Check valve down thru the floor and goes to the tank. Follow that line until it goes to the tank, then chip away the foam to access the nozzle. I would bet you will find the nozzle holes clogged up. I would rather replace than removing and cleaning out, but they can be easily cleaned once removed. Saving $35. Just messy. WEAR Latex GLOVES! Doug
About Fifth Wheel Group
