Trix
Dec 01, 2013Explorer
naspaz wrote:
1. We have a small seam separation on the front, driver's side (just forward of the bedroom slide) when hitched. I've tried different caulkings with almost success. I'm getting ready to try eternabond on it - something others say works for them. The seam separation could possibly be evidence of a broken weld, but not likely. Check the unit out to see if there is any evidence of this problem.
We had the same seam separation on our 2007 32.5 UKTG. There has been a problem with broken welds on the aluminum frame, so this is an issue you should investigate; check the Nuwa forum. HH can repair them perfectly, and I believe others have reported good results at dealers. We got a MH last year upon the insistence of my lovely DW. If it were up to me, I would have kept the HH for a very long time, and repaired the welds if the separation became worse. It was a solid unit for the money, very well built and great floor plans.
Good luck!
Good luck!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
