dedmiston
Jul 29, 2019Moderator
Stepping in as a moderator to give my opinion:
You're seeing a wide range of opinions, many of which I consider to be absolutely wrong and from members who have no experience with toy haulers.
For the sake of the peanut gallery, toy haulers are designed with their axles much further back so they can carry much heavier cargo (bikes, quads, rails, side-by-sides, etc.) in the rear. This means that they have way higher tongue weights than common travel trailers.
Our last trailer was a 30' bumper pull toy hauler. My setup was very safe and it pulled fine, but I had a good WD hitch with heavy duty sway control (not a $140 sway bar). I towed for the first 9-12 months without the sway control and it was a rough ride. The sway control made it much safer and easier to tow.
For starters, don't even consider a friction sway bar. Those are made for much lighter trailers and they'll snap like balsa wood on a trailer this heavy.
When I bought our 30' TH in 2004, I went with the Reese heavy duty weight distribution hitch. One of the reasons I bought this was that it was designed so I could start with the WD hitch and then add the dual-cam sway control later.
Honestly, if you're not already familiar with the concepts and technology and you're as eager to pick up your new rig as most of us were at the time, the $750 for a good Anderson hitch installed properly really isn't that bad. You can go to https://www.etrailer.com to shop around and do some homework and see if it's practical to beat their price. Watch some of their videos and get familiar with the tech.
In the meantime, beware of some of the free advice (including my own) that you're getting here. Some of it is downright horrible.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
