L8173's avatar
L8173
Time to pick your brains about anti sway bars ...
It's probably here already, but I'll ask anyway. I recently purchased an ATC 8.5X25 bedroom. I've yet to take possession because the dealer said that I need an Anderson Anti-sway hitch for it. Having not pulled something this large (30' and to end), I was reluctant to say no. First, I was told that this $750 hitch was necessary due to how large the trailer hitch is. Is this true? Meaning, are there others available? Secondly, I'm pulling with a 2019 F250 with a 6.7 diesel. Is the anti say bar/hitch really necessary? Obviously I'm a novice, so be kind, lol. Any input appreciated.
  • It might be a weight distribution system with anti-sway bar.
    Alone, an anti-sway bar costs only about $40.
    And you don't actually need a weight distribution system if you have so much allowance between your truck's tow capability and the actual gross weight of what you are towing.
  • K Charles wrote:
    If a weight distribution hitch is set up right, you can get away without the anti away stuff.
    “YOU HAVE EVERYTHING GAIN AND NOTHING TO LOOSE WITH A GOOD SWAY BAR SYSTEM” Safety should always be your top priority!!!! I like the Reese Dual Cam system.
  • I should clarify... It's my understanding this is a weight distribution hitch as well as an anti sway bar.
  • If a weight distribution hitch is set up right, you can get away without the anti away stuff.
