- allcoolExplorer
freewayrandy wrote:
I'm considering new wheels on my 2010 Fuzion TE II, factory wheels are 7" wide, new wheels are 6". Would there be any issues I could expect running a 1" narrower wheel?freewayrandy wrote:
fj12ryder wrote:
Why new wheels? What tire came on the trailer from the factory, and why do you feel you need to change sizes?
I like the new wheels better than the factory and I got a super deal on them brand new.
Might want to clean up those old 16 x 7" wheels and store them away, for when you see the LT light...
jmo - joebedfordNomad IIMake sure you get rims rated for 110psi in case you ever want to go to heavy duty tires.
- freewayrandyExplorer
face_down wrote:
Check the specs on the tires you have now...that will tell you what the rim width range is. For ex. a 235/80-16 Goodyear Marathon has approved rim widths from 6.0-7.5"
I'm running Maxxis 235/80-16 so guess I'll be good. - freewayrandyExplorer
I like the new wheels better than the factory and I got a super deal on them brand new. - EyetattooExplorerAs long as the new wheel dimensions are within the range of the tires you will be fine.
- face_downExplorerCheck the specs on the tires you have now...that will tell you what the rim width range is. For ex. a 235/80-16 Goodyear Marathon has approved rim widths from 6.0-7.5"
- naytherExplorerI would not go to a narrower wheel, same size tire will not wear correctly and smaller tire may not handle the weight.
You need to consult a "real" tire/wheel expert. - fj12ryderExplorer IIIWhy new wheels? What tire came on the trailer from the factory, and why do you feel you need to change sizes?
- ScottGNomadThat would mean using a narrower tire that more than likely has a lower weight rating.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
