klr650goldwingExplorerAug 06, 2018Tire ClearanceOur 5er currently has 3" of clearance between the top of the tires and the trailer. If larger tires were installed, and that clearance were reduced to 2.5" would those tires rub on the trailer?
CALandLINExplorerAug 06, 2018The best answer for that may come from the axle manufacturer. The ones I've seen information on have a 3" - 3.5" minimum range. It's also a question a savvy tire installer would figure-out before installing tires taller than the Original tires.Click Here!
Related ContentTires rubbing on camper 2 inch clearance ?Bias ply vs. radial tiresGround clearanceTire clearanceClearance
