rockbuster
Jun 26, 2014Explorer
Tire help
So I've had our 5th wheel for two years and started looking into tires. I've read and searched all kinds of tire threads. The tires oem tires are 235/80r16 E. The rims are good for 110 psi and made f...
The rims are good for 110 psi and made for 6 inch tires. The tag on the trailer says the axels are 6000lbs and 11900 gvw, tag also says 65psi. Between the tires there is a little over 2 inches of space now so larger sizes are going to be too close, and most other sizes the same height require a 6.5 or larger rim. I am not to excited about putting cheap st tires back on. I've looked at xps ribs, good year g614, sailun and Bridgestone and nothing seems to meet criteria with a 6 in rim. Any ideas?
