buck_n_duck
Aug 13, 2020Explorer
Tire help
Is there anything wrong with going overboard on load range rating? My trailer came with load range d tires. I had a blowout within 1 year of just being a weekend warrior. Thinking of going to a load r...
ford truck guy wrote:
If your asking what your rim is rated for... pull it off and check the inside of the wheel ( opposite side of air valve)... it will be stamped..
IF you crawl under the camper with an flashlight, you may be able to see it there without removing
