Shoe2728ExplorerMar 10, 2015Tire inflationGot E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...Show More
Cummins12V98Explorer IIIMar 10, 2015As usual more info would be needed to answer your question!Did you upsize your tires? What is your RV? Did you replace with same exact size and load range?How much weight is on each axle?Is 9,000# the weight on the ground or the total weight of the RV?What tires did you buy? Size/brand.
Related ContentTire Load/Inflation CalculationBest tire inflator for dually tiresTire inflationTire inflationsTire Inflation Dilemma
