Shoe2728ExplorerMar 10, 2015Tire inflationGot E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...Show More
N-TroubleExplorerMar 10, 2015A tire guy that doesn't know his stuff...Rated PSI is COLD. Tire manufacturers already factor in PSI increase with temp.
Related ContentTire Load/Inflation CalculationBest tire inflator for dually tiresTire inflationTire inflationsTire Inflation Dilemma
