Got E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...
My trucks tire label lists 65 psi for the front and 80 psi for the rear... No other inflation info is provided. I can only assume the label is referring to max payload operation.
Empty... I believe 80 psi is over inflated for the rear. I run 65 psi in the rear when empty.
