Shoe2728ExplorerMar 10, 2015Tire inflationGot E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...Show More
wandering1ExplorerMar 11, 2015Run 80psi. Under or over inflated tires heat up. Excess heat will damage tires. Get the facts contact the tire manufacturer.
Related ContentTire Load/Inflation CalculationBest tire inflator for dually tiresTire inflationTire inflationsTire Inflation Dilemma
