Shoe2728
Mar 10, 2015Explorer
Tire inflation
Got E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...
Shoe2728 wrote:
I had St 235 80R 16E went to BF Goodrich Commercial T/A All-Season 235 85R 16E GVW of FW is 12000. I have looked for a pressure weight table but mostly all I fine is max inflation rate is 80 psi. I have a 2011 crossroads cruiser 305skp
