Got E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...
Trailer tire design recommends less traction and less grip for better performance in trailer application. A trailer tire should be better at sliding that steering. This is the main argument with putting LT tires on a trailer application. The people of this group require that you drink the koolade and forget about suspension performance. Or just wait five minutes and they will contradict themselves. MM49
