Shoe2728
Mar 10, 2015Explorer
Tire inflation
Got E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...
MM49 wrote:Me Again wrote:
OK, boys and girls, I took this picture in Lost Wages last month of a semi trailer next to me at Circus Circus RV:
Then I turned around and took a picture of my trailer tires:
You really need to learn to chew gum and think. There are many other aspects of tire friction, construction, compound, air pressure and many other items. The same engineering goals still stand. Just like the last 30 years.
MM49
