allen8106 wrote:
I have a similar situation. I have a 5ver the weighs in at 10,500 unhooked. Now I haven't yet weighed the axles or the truck axles. I just upgraded from GY Marathons with a D rating to Maxxis with an E rating. My problem is that the aluminum wheel is supposedly only rated for 65 PSI yet the tires are rated for up to 80 cold. I just completed a 2000 mile round trip to Mesa, AZ and ran the tires a 65 PSI cold. I have a TPMS and observed that the tire pressure grew from the 65 cold to as much as 80 PSI running down the road on a day where the ambient air temp was 65 degrees.
Interesting, if the 5er weighs 10,500 total, then the pin would be between about 2,500# and 1,500# so seeing how this is most assumptions anyway, say pin is 2,000#.
Then the axle weight would be 8,500#, assuming 235/85-16 E rating is 3,042# X 4 = 12,168#, 8,500/12,168 = 70% of total tire capacity. Not having an inflation chart 80*70% = 56 psi, likely an inflation chart would be at 60 to 65 psi.
Contact your dealer for an inflation chart.
