avvidclif1 wrote:
NC Hauler wrote:
avvidclif1 wrote:
NC Hauler wrote:
avvidclif1 wrote:
NC Hauler wrote:
RAS43 wrote:
Well then I must be "asking for trouble", whatever that must be. I have been pulling trailers since '75 and never had any wear issues and only blew one tire, a Goodyear Marathon. And I do have a TPMS which has not indicated any issue. :C
Well then you're ok, though some refined calibration equip has found some TPMS off by as much as 10% at times...I use a high dollar digital read out that I can also have calibrated, so feel pt=retty good about it,
Look up the spec's on that gauge and let us know the percentage of error. Might be interesting.
It's a commercial digital read out for tires that I can check it's calibration with some pretty sophisticated calibration equipment that I can use ...It's within +/- 2 psi to actual reading.
You still didn't give a brand or the mfg spec's for accuracy. At what pressure was it calibrated?
Haltec Pro Series digital gage...I checked known/verified air pressures of 35 psi 65 psi, 80 psi and 110 psi against what the gage read at these known values.
I didn't check manufactures specs, Gage was recommended by a Quality Engineer in my company's tire division...
It's close enough for me to trust it's accuracy and feel ok with the readings. I just had some helpful insight into the gage I purchased. I also have a slime digital gage that I've used for years, and basing readings from the Haltec to the Slime, The $30 Slime is almost as accurate, close enough to not worry.
It appears I ruffled your feathers from the 3rd. degree I'm getting from you...Don't understand why, no reason for me to lie about a tire pressure gage and how I'm fortunate enough to be able to check it's accuracy..
No ruffled feathers just curious as to what brand is considered a "good" gauge and how much they cost. Google can't find a Caltech tire pressure gauge so I guess it was a moot point.
OK, I don't seem to hunt and peck with my right hand only very well..Since the stroke, I can't type with my left hand and need to do a better job of proof reading before I post. The gage is a Teltek, TLK139, ignore the price, I paid NO where near that. I attached an 20" flex hose to it and added the chuck that works on my trucks valve stem, then checked gage against a known /verified air pressures of 35, 50, 80 and 110 psi,, and compared what gage was reading to a known actual pressure
As to what is the best....I stated I have a SLIME digital read out pressure gage that is very accurate and use it most of the time, but will still compare at times with the Teltik, but that doesn't necessarily make it good.. 40 years ago or more I'd use a $1 gage and never had the first issue with tires on any vehicle ot trailer I owned...so all this may be WAY overblown( pun intended)
