Michelle_S
Dec 26, 2014Explorer III
I think I would be very caution running an 80 PSI tire in the mid 40s. With Radial Tires, you must keep enough pressure in them to keep the bead seated. If you run too low a pressure and go into a corner hard you have the possibility of roll the tire right off the rim.
About Fifth Wheel Group
