PhoneDude 8289 wrote:
I have the tst507 system.  It started to lose the signal from the front street side trailer tire monitor.  I replaced the batteries in all the monitors and same situation.  After about a four hour drive the street side front trailer monitor signal is lost.  Tried changing location of sensors with same results, street side front trailer tire monitor signal lost.  Wasn't like that last season.  Any ideas or help would be appreciated.
When you changed the location of the sensors did you also reset the position on the monitor? If you didn't reset them then the same sensor is going to show up at the "street side front trailer" position regardless of which tire it is on. You may have a bad sensor, that can happen.
