lee worsdell wrote:
Wonder what pressures I should run on my truck. 2017 gmc 3500 dually pulling a 15800 loaded trailer. I have a bit of back and fourth movement right now thought I would start with tire pressure. Have a tri glide pin box that had the bottom plate welded solid. Just put my b w back in last night took out the reese. Try that also.
Look on the side of your tires and you will see some raised letters telling you what is the min and max tire pressure for your tire. I would also double check to make sure your rim is designed and has the load capacity to hold the max tire pressure of your tire. On the inside of the rim there should also be written the max capacity of that specific rim. When in doubt, I drive my trailer to my local Les Schwab tire shop and they can tell you. With my 5th wheel at 14K when loaded i put 110lbs. of air pressure in the tires.
