I read this on etrailer.com āā->
You always need to keep your trailer tires filled to the max cold psi rating. If your current load range G tires have a 110 psi rating then that is what you need to keep them filled to.
Tire blowouts are a result of damaging a tire (like hitting curbs), under or overfilling a tire, exceeding the speed rating for the tire, exceeding the weight limit, or even messed up suspension parts.
For example, the Provider ST235/85R16 Radial Trailer Tire # TTWPRG235R16 has a load range G which is 4,400 lbs at 110 psi for a single tire application like what you have. It also has a speed rating of M which is 81 mph. If you don't have the tire filled to 110 psi then it will get hot quickly and can cause a blowout. Most trailer tires have a speed rating of 65 mph so if you were exceeding that speed limit then that would also explain the blowout.
