ChuckSteed wrote:
Sailun tires are as good as any GY tires made for RVs... personally I run a Geo Star Chinese made G rated 14 ply tire... starting 4th season... r7n them at 105 to 110 psi...
They will continue to perform quite well... GY G614 is a nice tire but not worth the cost factor when a good G rated 14 ply tire will work just as well
If you’ve got money to burn then buy the best....Sailun would be your huckleberry
I was using the GY G614 16 inch and changed into the Sailun S637 235/75R -17.5, for $178 per tire delivered.
The same GY tire/size would have cost me almost 3 times as much per tire, for the dubious process of obtaining a replacement tire in the event of a covered failure. Dubious since I had already experienced the process once, and it was definitely not "plug n play".
The Sailun tires are substantial in their construction; the sidewall strength is impressive, and the performance has been flawless. They are manufactured under ISO 9000 standards, and when I (soon) replace my TV tires I will be going with Sailuns there as well.
